Vacuum Pump
chief1983
Saint Charles, MO
I have a specific question about the vacuum pump. The TMs don't go into any real detail about the pump itself. As far as I can tell, I have a dead pump. I hooked the Actron gauge up to the hose running directly from the pump to the regulator, and the gauge registered absolutely no vacuum. I'd have thought a pump that has failed this spectacularly would have been making some sort of noise, something etc. Is it normal for a failed pump to just be completely seized and have no audible signs of trouble? I've already got the new pump in the mail, but I've never dealt with a failed one before and just wondered if this is normal.
Warthog
245
OKC, OK
A functioning pump should provide about 20" of vacuum.
There is a diaphram inside the top housing. It can go bad.
Also the drive gear has a roll pin in it and it can shear off.
Easy to remove. Only one bolt. Pulls out just like a distibutor on a gasser engine, except you don't have to worry about the timing.
When you pull it out, make sure all the parts come out. If not you will have to use a magnet or parts retriever to get them out.
There are rebuilt ones at the parts store.
Here is one : Cardone 64-1201
Cardone Remanufactured 64-1201 - Vacuum Pump | O'Reilly Auto Parts
