cucvrus
- 9,682
- 113
- Jonestown Pennsylvania
What would be wrong with good used 6.2 CUCV lines? I mean if they are not rusted and torqued when applied they should work just fine. These should be out there readily available. I will throw my hat in the ring to sell you a used set. Or you can go this route. Used would be 1/2 the price and when running and not leaking you will never see the new ones as a bargain. Over torqueing could have been the root cause of all these leak issues. Good Luck.
