Page 37 of 40 FirstFirst ... 27 33 34 35 36 37 38 39 40 LastLast
Results 361 to 370 of 398
Thread: I have joined the Goat herd
  1. #361
    4 Star General combat32's Avatar
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    40
    Default
    Parts kit showed up Saturday from Red River
    Attached Images Attached Images
    Tom
  2. #362
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    40
    Default
    Started tear down and inspection today, she was funky inside, gears in good shape just the upper and lower bearings on worm shaft are toast.Haven't done one of these before but the step by step instructions are in the -34, how hard could it be?
    Tom
  3. #363
    4 Star General mkcoen's Avatar
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    967
    Default
    Quote Originally Posted by combat32 View Post
    Well if the fresh out of AIT E-2 screwed it up Uncle Sam just bought a new one. I don’t think he’d do the same if you do. Good luck! No pressure
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
    US ARMY - Overlanding since 1775
  4. #364
    4 Star General m38inmaine's Avatar
    Join Date
    Nov 2006
    Maine USA
    Posts
    2,095
    680
    Default
    If you need any parts I'll send you the spare I have, good progress.
    SSG USA(RET)
    85-05
    12B Combat Engineer
  5. #365
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    40
    Default
    Got a little painting done today, more of an experiment, i see lots of sanding I'm gonna have to go back and do. Finally got my front steering gearbox adjusted out about right. I don't have a lot of the special tools and adapters they used in 3rd shop back in the day when rebuilding these so I made do. My kit was in good shape considering it was boxed up in 79.
    You have to pay special attention as you have to set the pre load on the the bearings and gears in 3 different places to get it right, pretty happy with how it came out. Doing leak test today, TM call for 10 psi for 10 minutes should be no leaks, I don't have what it takes to pressurize it, so just filled it halfway with 90 wt, and look for leaks, so far none.
    My only worry it the top race on my worm shaft was pretty rough, tried to smooth it up best I could, but I have a feeling I'll be back in here in a few years, in the meantime I'll be looking for a new worm shaft to squirrel away till then.
    All other gears looked great, the design of this box sucks, or I should say location, think I'll always try to park nose uphill to keep the water out.
    If no leaks I'll put it back in tomorrow.
    Tom
  6. The Following User Says Thank You to combat32 For This Useful Post:
    m38inmaine (06-22-2018)
  7. #366
    2 Star General Gamagoat1's Avatar
    Join Date
    Sep 2006
    Elizabeth, Colorado
    Posts
    728
    142
    Default
    That puts grease between the shaft and bushing in the spindle. Not the wheel bearing,
    Check the LO. number 6 in the notes.
    By the way, that bushing is phenolic.
    Mike
    MVPA #171
    MVCC
    USN 4/64 - 7/72
    1971 XM-816 "Cap'n Hook"
    1972 M-561 GamaGoat
    "The Only Easy Day Was Yesterday"
    God, Bless America!
  8. The Following User Says Thank You to Gamagoat1 For This Useful Post:
    combat32 (06-18-2018)
  9. #367
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    40
    Default
    Happy 4th!
    Tom
  10. The Following 2 Users Say Thank You to combat32 For This Useful Post:
    m38inmaine (07-04-2018), mkcoen (07-03-2018)
  11. #368
    Moderator Warthog's Avatar
    Join Date
    Mar 2008
    OKC, OK
    Posts
    13,797
    1,521
    Default
    Happy 4th Tom.
    Its been three years and you haven't finished? I thought it just needed the engine buttoned up and it would be good to go. What loser did you buy the hunk of junk from?
    "We are all born ignorant.....but one must work hard to remain stupid" - Benjamin Franklin
  12. #369
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    40
    Default
    You know, its just one of those things, life keeps gettin in the way, makin good progress this year.
    Got hood re installed yesterday, took forever, lots of tweaking and adjusing to get it about right, what a pain!
    Tom
  13. #370
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    40
    Default
    The hood is pretty and green, kinda looks like a cherry on top of a turd, no pics but will post some in a few days, hotter than fire here.
    Tom
  14. The Following User Says Thank You to combat32 For This Useful Post:
    m38inmaine (07-17-2018)
Similar Threads
  1. Possible new member of the herd
    By M923driver in forum M38, M38A1 and M170
    Last Post: 09-10-2012, 08:57
  2. Added another M1009 to the herd
    By Smokinyoda in forum CUCV
    Last Post: 06-16-2011, 19:59
  3. New addition to the herd
    By JB in forum CCKW
    Last Post: 08-07-2010, 20:49
  4. Need to thin the herd a little....
    By TACTICAL6 in forum M37
    Last Post: 01-11-2010, 17:25
  5. My herd of deuces.....
    By dm22630 in forum The Deuce
    Last Post: 08-27-2008, 16:40
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
