Page 27 of 27 FirstFirst ... 17 23 24 25 26 27
Results 261 to 269 of 269
Thread: Meet Mr Rusty
  1. #261
    4 Star General cucvrus's Avatar
    Join Date
    Dec 2012
    Jonestown Pennsylvania
    Posts
    7,574
    Thanks
    2,467
    Default
    DSCF6339.jpgDSCF6340.jpgDSCF6341.jpgThe brakes were tight and the wheel was hard to turn. I se why now. Easy fix. The tightening wedge is broken. I have extras. DSCF6342.jpgI pried the brake caliper away from the rotor to get some free play in the caliper. DSCF6343.jpgDSCF6344.jpgDSCF6345.jpgThe slide surface tells the whole story. I have DOT 5 in mine from bleeding the brakes. It helped a bit but wire brushing them with a rotary brush cleaned them up nicely. I added a new inner pad clip. It was Made in USA. DSCF6347.jpg Autozone. DSCF6348.jpgDSCF6346.jpgSlide surfaces all cleaned up and smooth. They don't need replaced. But I have new ones if they did. DSCF6349.jpgI used copper never seize and applied it to all sliding surfaces. The left side is complete and my Wife called me for lunch. Now onto the Right side. First obstacle. The stripped bolt in the bracket. I used a chisel and it came right out. Steel recycles and new ones are available. DSCF6350.jpgDSCF6351.jpgThat was easy. Another tip. I brushed never seize on the back of the wheels and the hub face where the wheel contacts the hub. The wheel was very rusty at the center and when I removed the very rusty 8 lug nuts the wheel came right off. I will add a bit of Copper never seize to the lug studs also again. Have a Great Day and Be Safe. I want to finish this right front brake and move onto another project in the woods.
    To argue with a person who has renounced the use of reason is like administering medicine to the dead. Thomas Paine: Founding Father Quote.
  2. The Following 4 Users Say Thank You to cucvrus For This Useful Post:
    firefox (07-14-2019), german m1008 (07-14-2019), rtk (07-14-2019), Tracer (07-19-2019)
  3. #262
    Join Date
    Dec 2012
    Posts
    7,574
    Thanks
    2,467
    Default
    After a full week of thunderstorms, extreme heat, high humidity, and hard work I am ready to go back to work on Mr. Rusty. I had some down time waiting for a block heater to arrive. I also wanted to take the time to clean up my shop and get all my tools accounted for. After working outside for 3 weeks and throwing all my tools at the doorway area I decided to clean up. In the past 6 months I have lost 3 sockets. Not bad but still losing tools sucks. I would rather break them. I bought 5 gallons of ATF, 2 gallons of 15 40, 3 gallons of Dex Cool and will begin replenishing the fluids bright and early tomorrow before the temps feel like 107*. I want to get Mr. Rusty back home and out of my driveway. I may do some spot sanding and painting on a few spots of the cab just to slow the decaying process. Have a Great Day. Stay Cool and Be Safe and Productive.
  4. The Following 2 Users Say Thank You to cucvrus For This Useful Post:
    firefox (07-19-2019), Tracer (07-19-2019)
  5. #263
    4 Star General Tracer's Avatar
    Join Date
    Nov 2008
    Hawthorne, NV.
    Posts
    2,074
    Thanks
    4,285
    Default
    Quote Originally Posted by cucvrus View Post
    FP-2228-CAYG-Clean-As-You=Go.jpg cucvrus, At this time I think I've got more than 3 missing. Good thing is I know there not on the truck.
    1972 M35A2C W/W, 1986 M105A2, 1953 M38A1, S250 Shelter. "He was old and wise, which meant tired and disappointed" T.E. Lawrence
  6. The Following 2 Users Say Thank You to Tracer For This Useful Post:
    cucvrus (07-19-2019), firefox (07-19-2019)
  7. #264
    Join Date
    Dec 2012
    Posts
    7,574
    Thanks
    2,467
    Default
    i started out early today. At 0800 it was 80*. Getting the old block heater presented a challenge. It is out now. It was dug in and hanging on. Very little coolant remained and I lucked out and was able to retrieve the crossbar that holds it in. It wwas laying inside the hole and I just reached in and snagged it out with my phalanges. In to change my clothes for the second time. And back out at it. I am enjoying my day and getting a lot of odds and ends completed. despite the heat I have the whole day to myself. I hope none stops by to louse it up. Making slow steady progress on jobs I procrastinated on. Going to have my outside work bench cleaned up for the first time this year. That's progress. With a little luck I may get to work on my M1009 project. I found out a while back I am in no rush. Have a Great Day. Stay COOL and Safe. Hydrate.
  8. The Following 2 Users Say Thank You to cucvrus For This Useful Post:
    firefox (07-20-2019), Tracer (07-20-2019)
  9. #265
    3 Star General
    Join Date
    Dec 2011
    Bergen County, NJ
    Posts
    872
    Thanks
    132
    Default
    96 F. and very humid here.
    Staying inside.
    When I was in engine room on ship in 'nam and the other ****holes in SE Asia, we
    used to put Kaki's in sink and soak with water.
    Feels a little strange, but the wet Kaki's would cool you as they dried in the high temps.
    If I HAD to work outside in this heat, that is what I would do.
  10. The Following 3 Users Say Thank You to o1951 For This Useful Post:
    cucvrus (07-20-2019), firefox (07-20-2019), Tracer (07-20-2019)
  11. #266
    Join Date
    Nov 2008
    Hawthorne, NV.
    Posts
    2,074
    Thanks
    4,285
    Default
    Quote Originally Posted by o1951 View Post
    Staying inside.
    o1951 your spot on. The weather here has been in the high 90s to low 100s but not too humid today. I find if I soak my cover and a cotton shirt not a synthetic one, I can get 30-40 min. of comfortable work time outside. Repeat when necessary.
  12. The Following User Says Thank You to Tracer For This Useful Post:
    o1951 (07-20-2019)
  13. #267
    Join Date
    Dec 2012
    Posts
    7,574
    Thanks
    2,467
    Default
    DSCF6354.jpgGetting the block heater out proved to be a real challenge. DSCF6355.jpgDSCF6356.jpgOnce it was out I used the rotary brush on the drill and cleaned the hole really well. DSCF6357.jpgIt did have a spot on the element where it was in contact with the cylinder inside. I read that it must not make contact with anything inside the engine.DSCF6359.jpgDSCF6360.jpgDSCF6361.jpg
  14. The Following User Says Thank You to cucvrus For This Useful Post:
    Tracer (07-20-2019)
  15. #268
    Join Date
    Dec 2012
    Posts
    7,574
    Thanks
    2,467
    Default
    DSCF6358.jpgDSCF6362.jpgI did manage to get the nuts and the rusted flange from the left exhaust manifold. I choose to do that before I sent it to the exhaust shop so they could just heat the manifold and get the studs out. I was laying on cardboard in 100* weather and the exploding rust particles were a real joy. I did not get burnt and suffered no injuries today. DSCF6363.jpgDSCF6364.jpgDSCF6365.jpgDSCF6366.jpgAll in all Mr. Rusty is NOT a bad CUCV. It is not any rustier then a lot of others I see. It runs and drives great. I am finished with my part. I gave Mr. Rusty a complimentary scrub down inside and out. I took it for a 10 mile drive it drives nice and shifts perfect. It has 373 gears so it can run along at 70 mph really nice. The lack of exhaust is very noticeable when pulling out but cruising it just goes away and seems like a loud muffler. My part is done for another year. I did put 1/2" rubber hose on the door strikers and oiled and greased every moving part on the truck. I pressure washed out under it good and it still has slag falling when you hit the frame with a hammer. Ready for a few more years of plowing. It is still a decent truck and is up for the job. Everything under the hood is stock and the entire electrical system is as it was made. It still has AC Delco 13 G glow plugs. This is living proof that they will just keep going and don't need any modifications at all. Well the bed that rotted off. Th trailer bed seems to fit and holds up well. Have a Great Day and Stay COOL. Today was 3 complete changes of clothing and 2 extra white shirts. All done now and in the A/C.
  16. The Following 4 Users Say Thank You to cucvrus For This Useful Post:
    firefox (07-20-2019), german m1008 (07-21-2019), o1951 (07-20-2019), Tracer (07-20-2019)
  17. #269
    Join Date
    Dec 2012
    Posts
    7,574
    Thanks
    2,467
    Default
    I drove Mr Rusty to the exhaust shop and dropped it off for new exhaust. Still not going with SS exhaust. Waste of money at this point. It is almost double the cost. And Mr. Rusty like any other 35 year old hard road driven vehicle has the time bomb is ticking away. Anything could happen. Yesterday in the sweltering heat wave I did manage to get some help from my family and friends to rearrange my barn and get a lot cleaned up. I had a 2 CUCV owners there and made their day with some parts they were excited to have. Many freebies and easy come easy go items. And much to my surprise I found not 1 but 2 sets of preformed original OEM GM automatic transmission lines. They look like new and had the clip that attaches them to the flywheel cover. I needed 2 of them clips. I found many things that I had forgotten. Sadly I found a couple yards of the original vinyl seat material and it was mouse chewed. Oh well. That's life. I keep the cats out of my barn for good reason. Some go in to die and that is worse than a few lost yards of vinyl. Have a Great Day. Be Safe. Stay Cool.
  18. The Following 2 Users Say Thank You to cucvrus For This Useful Post:
    firefox (07-22-2019), tomztoy (07-22-2019)
Similar Threads
  1. Cleaned Up Rusty Bed
    By rneely in forum The Deuce
    Last Post: 09-15-2011, 11:01
  2. repairing rusty bed
    By John S-B in forum The Deuce
    Last Post: 07-02-2011, 08:54
  3. Top End Maintenance/Ol'Rusty 10 Ton
    By Dirt71 in forum 5-ton and up
    Last Post: 05-17-2011, 02:45
  4. What is this rusty old M37 worth?
    By rusty_m37 in forum M37
    Last Post: 04-09-2009, 11:08
  5. New guy from Germany with rusty m1009
    By 84cucv1009 in forum Requirements For New Members
    Last Post: 12-26-2008, 15:56
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
