Page 9 of 9 FirstFirst ... 5 6 7 8 9
Results 81 to 85 of 85
Thread: Dual fuel tank install
  1. #81
    Private
    Join Date
    Aug 2017
    Richmond, VA
    Posts
    15
    35
    Default
    Rusty,
    I finally have completed my auxiliary tank installation using your design as a guide. I used the motorized valve that you suggested and it works great! I mounted it under my heater box on the drivers side fender. I mounted my check valves on the inside of the frame rail near the primary fuel tank and ran the line to my aux tank across the cross member. I also mounted my "tee" connection for the vent line there too. I used copper tubing except for the ends at the fuel tank and the valve, where I used stainless steel flexible lines for ease of installation. I mounted my switch in the same empty hole on the dash as you did! Except I mounted mine "sideways" to differentiate between the left (Aux) tank and the right (primary) tank. 20190920_153058.jpg20190920_152958.jpg20190914_161013.jpg20190907_133436.jpg20190817_165223.jpg20190901_140637.jpg
  2. The Following 4 Users Say Thank You to Modiconman For This Useful Post:
    ALFA2 (10-19-2019), firefox (09-27-2019), peashooter (09-27-2019), silverstate55 (09-28-2019)
  3. #82
    Private
    Join Date
    Aug 2017
    Richmond, VA
    Posts
    15
    35
    Default
    Also, here are my diagrams of the system as installed.CCF09262019.pdf
  4. The Following 2 Users Say Thank You to Modiconman For This Useful Post:
    firefox (09-27-2019), silverstate55 (09-28-2019)
  5. #83
    4 Star General rustystud's Avatar
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,355
    2,358
    Default
    Nice job !!!
    Looks almost factory !
  6. The Following 2 Users Say Thank You to rustystud For This Useful Post:
    ALFA2 (10-19-2019), firefox (09-28-2019)
  7. #84
    Private
    Join Date
    Aug 2017
    Richmond, VA
    Posts
    15
    35
    Default
    Thanks Rusty! I really appreciate all of your input, ideas and thanks a bunch for the compliment!!!!!!!!
  8. The Following User Says Thank You to Modiconman For This Useful Post:
  9. #85
    Join Date
    Sep 2011
    Posts
    8,355
    2,358
    Default
    Quote Originally Posted by Modiconman View Post
    Your very welcome.
  10. The Following User Says Thank You to rustystud For This Useful Post:
    firefox (09-29-2019)
Similar Threads
  1. Extra fuel tank install
    By Kgood in forum The Deuce
    Last Post: 06-12-2018, 03:20
  2. 1985 M923A1 Dual Fuel Line Mod and new Fuel Button Install
    By kennys@wi.rr.com in forum 5-ton Mods and Hot Rodding
    Last Post: 10-27-2017, 21:17
  3. Dual Tank Fuel Gauges Not Working
    By gottaluvit in forum 5-ton and up
    Last Post: 06-02-2015, 08:51
  4. Dual voltage alt install
    By 762NATO in forum HMMWV
    Last Post: 05-09-2014, 13:59
  5. Replies: 2
    Last Post: 01-17-2011, 14:03
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
