Gunfreak25
- 620
- 113
- Yuma, AZ
Who you callin a newb?
Bought at 18 years old in 2010. Shipped from Tucson to Yuma. Pulled and scraped the junkyard 455 Olds and Th400. Installed a like new surplus M998 motor (NA), 700r4, Np231 for a reduction box. Moved original transfer back 5". Original hard top from Alberta. Repaired floor damage from fork lift. New carpeting (still in works), upholstery, rebuilt all wiring, 4 Core Chevelle Radiator, tranny cooler, NOS 24v fuel pump, York 210 for the brakes. Highly modded 7.3 powerstroke fuel bowl filter to work with 6.2 Diesel. Still to do is put new rubber on, 12 new wheel cylinders, finish making brake lines, rebuild AIR PAK, exhaust and finish fabbing up my own linkages. I want it to be 110% good to go when done so I don't have to be putting money into it as a daily driver. When done the engine compartment will be pretty full. I am overlooking nothing and taking my time.
When I bought it in 2010 I did not know what a carburetor was and thought mufflers had bearings.
I am 20 now by the way. 21 in July.
