ether bottle - quick start
319cssb
221
Easley SC
Ether system
I got to get the ether bottle replaced. Is there a common part number and does it screw right in or do i have to make modifications?
Guyfang
22,090
Burgkunstadt, Germany
Bottles must be standard. In the early 70's, we got them packaged in CATERPILLER boxes, and later still, in some other big name company boxes.
porkysplace
1,485
mid- michigan
The 1 local truck parts store that stocks a few different styles and at least 2 different threads on them. And now Cat has their own system and their own style bottles.
Most equipment dealers around here quit stocking them a few years ago when they jacked up the hazmat fees on shipping .
319cssb
221
Easley SC
Yeah , what about refilling them? I wondered what the big issue with that is? Seems to have a standard valve.
porkysplace
1,485
mid- michigan
Not really designed to refill. How much do you really need ether in South Carolina ? a new bottle should last a few years .
Are you sure it is empty ? You know it will only squirt with the engine cranking right ?
Ronmar
6,605
Port angeles wa
And with the coolant in the bypass pipe below 32F since the last time the engine was above 88F...
Karl kostman
836
Fargo ND
I was at the CAT Freightliner dealer in town for some other parts and needed a bottle for the 977 and they dont sell them anymore, he said all our trucks now have plenum heaters and they have no use for the Ether anymore and the last case they had finally ended up be thrown in the garbage?
Karl
319cssb
221
Easley SC
Good point porky
today i started the truck without ether. Took a bunch of cranks.
tomorrow ill try pushing that button for 3 secs wait 3 secs and then try to start the engine. See if it does any better.
But yes you are right, i dont know if it is indeed empty, for sure yet.
319cssb
221
Easley SC
When i push the ether start button. Dors it make a noise , like a hiss or so?
if it does then my bottle is empty, because i don't hear anything.
Master on, of couse and push the bomb button for 3 secs
