1958 Kaiser M52A2 Stuck in Reverse
SneakerZed
Casper, WY
My M52 is literally stuck in reverse. The clutch does engage/disengage the transmission. The stick shift is very loose and it feels like the stick shift came off inside the transmission. Any suggestions? Can I unbolt the stick shift cover and take peek without have stuff fly out?
What TM would show me the details of the transmission to include the stick shift/lever?
Thank you
SneakerZed
Casper, WY
RIGHT ON! That may be the issue. So can i unbolt the cover on top of the transmission to look?
Does this fit the M52?
mdemars03
El Paso, Texas
Which cover are you trying to take off? I took off all of the channel covers on mine and was able to get to and remove the transmission (yes by dropping it down but there was still a decent amount of stuff to disconnect) without cutting any of the floor. With the transmission channels unbolted and pulled off you have quite a bit of room to work. I would double check before you start cutting the floor.
SneakerZed
Casper, WY
The "Shift finger" had come loose so I was able to remove everything and re-assemble without an issue. But I will still need a new shifter. So what specific "Gear Oil" do I need to put in the transmission? I am trying to hunt it down now.
sandcobra164
287
Leesburg, GA
In mine, I ran 40 weight non-detergent engine oil. I had a noticeable drop in transmission temps. I got the idea from member M35 Tom. He does some very impressive work to include a taller overdrive for the Deuce's.
mdemars03
El Paso, Texas
As MyothersanM1 said, 50 weight oil is best for the Spicer transmissions. They still recommend 50 weight for the transmissions they make now. Granted I know the newer transmission from Spicer are quite different from the transmission in a MV, but the lubricating properties of the oil remain the same.
There is what Spicer shows on their website. Just my 2cents
