1968 m 151 a1
lw3443
Rockwall Tx
Hello,
I am new to this site. I currently have a 1968 M151 A1 (MUTT) that I am trying to figure out the value off. If anyone has any info on this then please reply. It does currently run and drive but does need work.
Thanks,
LW3443
lw3443
Rockwall Tx
If you look at the picture of the Motor you will see the radiator fan spinning. Just to show you it was started when I took the pics. Thanks in adavance for any info that I can get on this!!!
txdodge43man
Magnolia, texas
depending on the condition of the under side of the jeep body. Do you have a texas title? I would say its a pretty clean un cut M151a1 and 4000.00 would be a good price.
lw3443
Rockwall Tx
I do have a clear Texas Title. I was given this jeep by my grandfather when his health got bad. I beleive he purchased it sometime in the early 70's but im not exactly sure. I learned how to drive behind the wheel of this jeep!!
Thanks,
Lance
vtdeucedriver
40
Vermont
Lance.
You really need to look underneath the jeep. Look at the 2 main frame rails that run from the front to the back. Look at the back area where they curve up and out and the area where they come across and the rear suspension arm bolt to the center area!!!! If this area is not rotted, this is a big PLUS!!!!! Next, pulll up those rubber mats and look for a weld that comes across between the seat areas. This will tell us if it is UNCUT. IF, these areas are OK, you could get $4K for that jeep with no problem!!!!! If these areas have problems, it will go down from there.
Come to the M151 forum.
www.g838.org
maddawg308
825
Appomattox, VA
Ditto on the 4K price tag. Looks pretty good to me, except for the paint job. Looks like a polished turd. Nothing some paint and accessories can't fix.
