billbot
- 28
- 13
- Bakersfield, CA
Been looking for a little while and reading up here. Seemed simple enough. Got kind of a beater at auction. It's a 2008 Fermont with 3500 hours on the meter. Began to feel a little overwhelmed once I got the thing home.
Started with the basic stuff - changing oil, adding coolant and new coolant bottle. Have yet to do the fuel filters and the air filter minder looks good so far. I have replacements just haven't gotten to it yet.
Hosed off a ton of dust inside the engine compartment and blew out the dust in the control box. Hit that a few times actually.
Had some old batteries from my truck, popped 'em in and it fired right up. I couldn't believe it. Alternator not charging - found a blown 10amp fuse and replaced it with the proper one. Easy so far.
Noticed major carbon chunks coming out the exhaust though.
Finally got around to the load test last night. Ended up getting some heater elements totalling 10kw load. Did fine at 7k but going up to 10k the overload tripped after a few minutes. It was already getting late and I was overall pleased with the result but still a little worried.
Got back on this site and did some searching. This morning I got out and really blew out any connections I could get to, then started checking them with a screwdriver. Tightened everything up I could get to. Exercised some of the switches and fired it up.
Did great at 7k, still spewing lots of chunks but exhaust is clean with no smoke except at startup. Put the full 10k on and checked with clamp meter and got 40 on each leg. Ran it for 30 minutes with no issues. Couldn't believe it.
Seemed like the chunks were getting less, but need to get that taken care of. I'm thinking if I run for a few hours at 7k should be good.
Thank you all for the amazing contributions you have made. Just wanted to share a success story.
