2015 M1123, what TCM do I need?
alwayskaos
17
Lake Havasu City, Az.
I've spent hours now trying to figure out what the part number is for a completely missing Transmission control module. Does anyone know where I could find the info, or possibly know the part number of the unit I need? Thanks all
springer1981
1,148
Maine
The TCM is basically a standard GM part but mounted in rugged case with military connectors. They had different TCM's for different years and there were a couple different model years for the 4L80. Do you want to retain the stock HMMWV setup? There are many stand alone aftermarket TCM's that work excellent but it depends on how you use the truck somewhat. I used a US Shift Quick 4 and am very happy with it.
What year is your truck? Also you should make sure you know what transmission you have, early or late. Do you have the TCM housing?
Page 148 of the attachment might help
alwayskaos
17
Truck is a 2015 M1123
That was a ton of help my friend. I just woke up, getting my coffee, and I'll go thru that attachment you sent me. I was thinking a plug and play original init would be best, but I'm open to anything. I just need to get this vehicle working sooner than later. I have an aircraft maintenance facility, and I purchased this truck just for airport use as a work vehicle.
Coug
4,124
Olympia/WA
truck may have been rebuilt in 2015, but to my knowledge they stopped building new A2 series trucks around 2009 (all M1123s are M998A2 series vehicles)
All that really matters is whether it's serial number is above or below 196900, as the engine belt system and a couple other things were updated at that serial number break (though during rebuild sometimes engines got changed to the opposite style from what they had originally)
