24V headlights
bigflew
15
alpena michigan
I have a problem with my m998 that may or may no be a problem.
when I got the 998 it had no headlights so of course I ordered a nos set of 28 volt Wagner's after installing Corectly they both turned black inside and failed. checked voltage 24-26 volts.got 2 more light 1failed instantly.the other worked great on both sides.
I think I'm getting bad bulbs ? Warner manufacturing date of 08
The HUlk
Cincy, OH
Physical shock & vibration (especially when lit) will shorten the life of, or immediately break a lamp fillament.
Atmoshpere(oxygen) entering the bulb will enable the fillament to burn. This sounds like what may be happening resulting in the dark color you are seeing.
papakb
1,186
San Jose, Ca
I run Hella H4 lamps on my truck. They're considerably brighter than the stock incandescent bulbs. You do need to make up a short pigtail to go from the Packard connectors to a standard 3 pin lamp connector but that's only a 10 minute job. I have run the cheepie Autopals from India and they do work but their quality control isn't very good. I had to return the first set I got because the lenses were offcenter and the bezel wouldn't clamp down over them. The second set worked fine.
Kurt
85
Aurora, CO
KC makes a Lexan 7" Round lens that can be found on amazon pretty inexpensive. There is a small glow in the dark "KC" emblem on the bottom that I hate, but they work great and won't crack.
