jd 9760
- 0
- 0
- Van Wert, Ohio
1st question:
I changed the transmission oil in my truck today just a drain and fill no filter change at this time. I put a Napa R&O oil in which they claim is 10w oil. Seems to drive and shift fine but my trans temp is running betweem 220-225 degrees. I didn't pay much attention to it before I changed the oil so is that temp normal?
2nd question:
The seal on the out put shaft is leaking. Is there a Napa or other part number that may help me and how hard is this to fix?
3rd question:
When shifting into low transfer the lever is to close to the seat. When I try and shift to low my hand gets pinched between the lever and the seat is there a way to adjust the position of the lever and do others have this same problem?
2nd question:
3rd question:
