395/85r20 mraps tire rub issues
dezert ratt
menifee, ca
I am just waiting on a shipment of 1" bolts. Then I will be putting on my new rims and tires.
So I articulated the rear suspension today, checking how far from the bed the tires get.
With stock 9.00 ndt tires, I have about 1 1/2 inches of clearance before the tire rubs the bottom of the bed. So my next question is, how bad do the 395's on mraps rub on the deuce and a half? I am not looking forward to chunking up my brand new tires on the bed ribs.
What have you guys done or experienced to get around this issue?
It looks like I can pretty easily make some solid spacers to lower the rubber bump stops, but then we're losing articulation.
Or I could tub the bed and keep full use of the rear suspension. Has anyone gone this far?
gimpyrobb
dumpsterlandingfromorbit!
27,707
396
Cincy Ohio
I have been running 395s for years. Never had issues with them rubbing and "chunking" on the rears. The fronts have torn up my louvers on the inner fenders though.
VPed
68
Clint, TX
When they do rub, they rub on the outside curve of the bed reinforcements, not on a sharp edge. Just polished the metal some. I imagine it would be worse with quite a load on the truck but mine barely rubs with three quads and some coolers in the back. And that is that I know I have articulated the rear enough to alternately pick up each rear axle and tire sets. I saw an A3 go before me over the dirt berms that caused the articulation but his did not rub as he has a slightly shorter tire.
