5 Ton dump truck
Rocco
Lynchburg VA
Could someone put up some pictures of the dump box
in the up position so I can see the hyd pump set up?
And the PTO set up thanks.
houdel
11
Chase, MI
Bendawg said:
another sorry I dont know how to do more pics at once
Bendawg - After you enter your first photo, hit "Preview" rather than"Submit". That will preview your posting, plus open a spot to insert another photo. Keep hitting "Preview" until you have all your photos posted. Note in "Preview" mode they will appear in REVERSE order from the way you entered them, once you hit "Submit" they will appear in the correct order.
CGarbee
579
Raleigh, NC
Do you have all the parts for your conversion already or are you still in the planning stages?? I've got a cargo truck that was converted to a tipper parked on the farm just north of Charlottesville that I will be parting out soon (unless somebody wants to give me the $1600 that I paid for it...) if you need stuff...
Rocco
Lynchburg VA
Im still in the planing stages.
Does the truck run?
Does it still have the dump box on it?
And what shape are the tires in?
Thanks.
CGarbee
579
Raleigh, NC
Does the truck run?
Thanks.
The truck runs well, brakes need work as the fluid slowly seeps out so the guy I purchased it from said that he just topped it up once a month... Tires are good (in fact, one of the first things I am planning to pull if the truck doesn't sell as a whole are the tires/wheels). Lights need to be replaced, and in fact, the wiring in general is a mess.
It has a cargo body on it with the hydraulic setup underneath.
It's been used by a logger and just about every body panel has a ding.
