5 ton radio antena
panzerwillie
284
miami florida
Did any 5 ton tractor come with radio like my M52A2 and if so where was the antena mounted and what type of radio did they use any pictures would be nice ot a TM thanks;-)
wsucougarx
Washington State
considering the era, one of the posible radio's was more than likely an Rt-524a/VRC. Antenna could have been mounted anywhere behind the cab or perched up on the convoy light support. Many different possibilities on the antenna mount mounting locations.
KsM715
142
St George Ks
Heres what my truck came with from GL
Theres no radio mount, but there is a speaker mounted in the corner right behind the passegers right shoulder.
panzerwillie
284
miami florida
great information guys , i like the set up behind the toolbox, may go that rouet , i have 2 m35a3 seats if i do a radio i think will install it between seats, keep the info coming.... :idea:
mckeeranger
Eastern Kentucky
Because the M817s have a "headache rack" above the cab, they can't have the antenna mounted around the back. They have them mounted to the cowl, over the side vent. (see pic one) There is a little bracket that moves the mirror mount out of the way of the antenna, but I took it off. Don't worry, I have it. I keep everything.
The co-ax wires run along the side of the floor board, below the door. They have a metal cover to protect them that also blocks the drain holes. If you deep ford, you have to wait for the water to drain through all the small holes in the floor. (see pic two)
Pardon the messy floor board, it's been a nasty winter here. :|
Orionspath
Northern Virginia
While we are on the subject, could anyone elaborate on the placement of an antenna mount for the 2.5 ton? I have procured a mount, sugar scoop and the stand off block (looks like it mounts to side of the bed)
:cookoo:
I'd like to move forward on placing this in the coming weeks if it ever warms up here.......
popacom
9
winchester,ky
Saw this post and was thinking back to what I rememberd on that particular install,the common mt in my area was a mt that stradeled the cab air vent on the passenger side and mounted a standard "Sugar Scoop" have also seen a front fender mt(got some NOS ones of this one) I'll try to scan some of my reference photos and post them.
popacom.........KI4QQB in KY:beer:
Armada
Buick City, MI
i can seen to make the link work is there another way to see the pictures
thanks :roll:
Not sure why it wont take you to the thread with the pics? Seems to be working fine. Try it again. springer seat I dont have the photos with me or I would repost them.
