6 lug to 10 lug
sermis
17
Temple, TX
Are there any 10 lug hubs that will work on the 2.5 ton rockwells. I know there are adapters but at $350.00 and up for a pair, ouch.
sermis
17
Temple, TX
No, I get 5 ton combat wheels from time to time and really want to run the tires tubless. I made wider rims from stock but after mounting the tire, tube, and flap they will not balance. Would be really simple to mount tubless beadlocks and go.
jh1990
my dad and i have been trying to figure out a way to run a 10 lug on our deuce so we could put 22.5 tubeless on it. we havent had such luck. thanks Sermis for posting something on here, everytime i was going to i forgot.
CCATLETT1984
Saint Clair Shores, MI
why dont you just have a new center welded into the rim that you want to use. as long as its a pressed center you dont have to worry about any bending that could happen with a flat steel center.
sermis
17
Temple, TX
Main reason $$$$$$
CCATLETT1984
Shouldn't cost much. you can get wheel centers for $60 ea. for that size of rim. and a shop ususally doesnt charge much to weld them in.
or you can make a simple jig and weld them in yourself.
Blythewoodjoe
56
Blythewood, SC
I have a 6 lug wheel in 22.5" that I assume will fit a deuce. I will have to check but I have always assumed you can buy these rims new and it seems like I prices some a few years ago. I'll have to try to put this rim on my truck and report back.
Joe Trapp
OPCOM
29
Dallas, Texas
With the other wheel and tire subjects, this would be very interesting. semi-truck 22.5's would be great for the highway deuce.
Trango
23
Boulder, CO
I run the 6 lug 22.5's in the rear, and I made my own front rims out of plate centers welded into Dayton shells, to compensate for the wide rears.
PM me if you want more info.
