rivercreek
- 1
- 18
- Berryville, VA
M35A3 parking brake shoes. Old assembly removed without difficulty, but I seem to be unable to re-install the new shoe assembly on the drum. I hope that im missing something obvious here, but i've been scratching my head and searching posts for awhile with no luck so far. I was unable to locate anything in the A3 TM (9-2320-386-24-1-1) for this procedure so have been referencing the multi-fuel deuce manual (9-2320-361-20) which has a pretty clear procedure with one exception (perhaps just a typo?) Section 8.3.d assembly instructions do not seem to match the illustrations. The reference #'s don't seem to match the pictures. Still, unless there is something different about the A3 parking brake assembly and the A2 assembly, the procedure is pretty clear. As I said, I didn't have much difficulty removing the old shoe assembly from the drum, BUT there was practically no shoes left on the old ones. With the new shoes (added thickness), I cannot seem to get the lever up past the frame rail. Am I having a stupid moment here? What am I missing? I removed the old assembly clockwise (from behind drum, facing front of truck), but it doesn't seem possible to install new assembly the same way the old one came out (counter-clockwise install). There isn't room for me to install clockwise from the other side either. In any case, I sincerely hope one of you guru's can tell me what i'm doing wrong and I'll gladly smack myself in the forehead. I attached a couple of photos to try and illustrate my problem. Thanks in advance for any advice on this.
