Ferroequinologist
Resident railroad expert
- 4,813
- 750
- 113
- Liberty Hill, SC
Daniel,
I have the exact same problem logging in at work too. The IP changed, and the internet provider reclassified the site. I have tried to get it reclassified with no luck. I used to get on the site many times a day but not since the server replacement.
Doghead and I discussed this idea at length awhile back to get my m543 with the m936 bed running. A MEP002 was our best option. As Ron pointed out, you need almost a 20hp electric motor to run the pump with the same amount of torque as the stock setup. A 20hp motor is not little by any means. And require a large amount of electricity to run. I was going to remove the passenger fuel tank and mount it there, and plumb the engine into the fuel tank and the electrics into the trucks batteries with a start switch on the dash. It would definitely save fuel and be way less noisy than that 250 screaming.
Sorry to hear about your engine. That really sucks. Good thing you found out this way before you were flying down the road on an important mission.
