AJMBLAZER
- 7
- 0
- Paducah, KY
We all know that Alpha Heaven and some others have been throwing 36x12.5-16.5 HMMWV tires on the CUCV's in order to counteract the low gearing and in the case of the K5's to just look cool.
I like the stance and I like the look...
...only problem I've found so far is that Alfa Heaven doesn't do anything to keep the tires off of the forward end of the drag link when you turn the tires all the way to the right...whoops. I always figured it was the tires rubbing the body but nope, it was the side lugs of the tires slowly dismembering the draglink's boot.
Need a new one now.
The simple, easy, and probably not long term fix was to redo the steering stop on the driver's side axle. Grade Eight 3/8" fine thread bolt about 2" long and a nut and that was it. I lost some turn radius to the right but not much. On the road driving wasn't affected, mostly just very sharp parking lot turns and such. Not that I tried many of those with a truck this big or long though.
Need a new one now.
