After looking all summer I finally won an 003 today
Rapracing
Western Pennsylvania
I kept waiting and bidding but never got what I felt was a price I could live with. I threw a bid on one today and low and behold I won :D
No I have to go get it and pray until then that there are no major issues with it. Hour meter says 3 hours. Pics look good but I guess you never know what your getting
1,187
You do if you preview and know what your looking at.
Rapracing
With out an in person preview there an numerous things that could be wrong. As I said the pics looked real good. I am in central Pa and it is in upstate NY do an in person was out of the question.
What should I have been looking for?
1,187
If it was at FT Drum, I was just there today and briefly looked at them.
I did not take notes as I was actually looking at other stuff.
1,187
Wish I knew 6 hrs ago.
1,187
A few that I actually looked directly at were drained of fluids and had filter canisters off. I looked in 2 of the fuel tanks and both had an inch or two of water in them. (no big deal really)
That's about all I recall.
Hope you lucked out and get a good one.
1,187
Depends where they came from. Some places drain all fluids(common).
Isaac-1
51
SW, Louisiana
Good luck on it, if the canisters are missing it is just a good excuse to go ahead and upgrade to spin on filters. I am just a couple of weeks ahead of you in the MEP-003a process, I have been bidding on them for a couple of years until I finally won an auction for one at what I consider an acceptable price a few weeks ago. I now have it running and am working on a variety of hopefully minor issues (it runs, but has high output voltage, and smokes on start up a bit much).
Ike
Rapracing
Ike
The canisters are there they are just removed.
How long does it normally take for the lot to show up in your lots won and also for an invoice to post?
1,187
The next day, usually.
Isaac-1
51
SW, Louisiana
Like doghead said, it is usually the next day, typically by noon, but sometimes it is up to 24 hours from end of auction, if longer than that call GL and see if there is an issue. My MEP-003a that I just bought was the slowest of all the non EUC things I have bought from GL with the invoice showing up just over 24 hours from the end of auction.
Ike
Rapracing
This was my first purchase from GL. I had purchased from GSA before.
I got an email at 1:25 saying the invoice was available. It still does not show in my account but they sent a link I can access it at. Stinks I have to pay 7.75% NY sales tax. Should have waited for one in Deleware.
It appears they must have just charged the card I have on file. The invoice is stamped PD In Full but it does not appear on that card yet. Probably after midnight it will be there.
Also, I thought I was seeing where there was an EUC required for these but apparently not?
TucsonVTXF
Tulsa, OK
You are good to go with a paid invoice!!!! no euc needed for a 003a.... You will get it running with the help available on here!!!!
Isaac-1
51
SW, Louisiana
GL's web site has a problem with the invoice tab not updating right (caching problem), your new stuff will sometimes show if you do a forced full reload on the page (shift reload in most browsers). As to EUC's that requirement was dropped a couple of years ago for generators and generators mounted on trailers. Yes, they charge the card on file, or pay-pal automatically that is part of the stuff you agree to in the fine print when you place the bid for items under a certain amount (high dollar items require bank transfers, I am not sure how high that is though, maybe over $10,000 or $20,000). Now you just need to schedule a pickup appointment and get it within the next 10 days or else it reverts back to GL and they keep your money.
Ike
Isaac-1
51
SW, Louisiana
The correct batteries for the MEP-003a are 6TL's these are very large, somewhat hard to find and expensive, a good alternative is a pair of group 24 batteries turned sideways in the tray plus a spacer on each side. (actually one 24 and one 24R so the positive and negative posts are near each other may work best). My only word of warning is using sideways 24's puts the posts very close to the hold down bracket, so use a lot of care.
