Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I just picked up a truck and the transfer case air shift switch under the dash is covered with oil and looks like it has been dripping on to the floor of the truck. It swells like gear oil. Any ideas as where this is comming from and how to fix it?
It probably is engine oil and the air compresser probably needs to be replaced. Have not had that problem with an MV but did with a mack. All the air valves leaked oil until I changed the compresser. Bleed the air tanks and see if they have oil in them, if so compresser is bad.
If it's engine oil it came through the air tanks... How'd they look when they were drained. They needn't be literally "full" of oil, but upon draining there would be no choice but to be ample evidence of such. My bet is on transfer case oil. How's the vent working?
I think someone posted that they had gear oil in their switch too. Have you made sure the vent is clean and working? I guess pressure could push through the line and pump GO to the switch. Easiest thing to do is pull the vent and check it!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
