alcohol dispenser
wallew
For INSIDE the cab dispersal or under the hood?
The reason I ask is because I ran across a guy who had hooked his 'windshield wiper water' switch to a new pump and stuck a bottle in his glove box. He would open a can of coke and then put it under the dash where he had installed a little spigot. Hit the switch and drinking and driving took on a WHOLE new meaning.
This WAS back in the mid sixties. Hey, if you need a highball that bad, perhaps you should pull over. He just laughed.
houdel
11
Chase, MI
Hey Bjorn - What would you think of mixing an ounce or two of air tool oil, or other light lubricating oil, such as CLP, to the methanol to provide a little lubrication to the top end of the air compressor? It would also make its way to the airpack, and a little lube there wouldn't help either. Of course, eventually the oil will end up in the air tanks and have to be drained out, but an ounce or so per 1000 miles isn't much to worry about. I kind of feel a very light oil mist in the air system might do a lot of good from a lubrication and anti corrosion standpoint. Can you think of any disadvantages?
Also, any way we can get back issues of MVM magazine to get the full story on your alchohol dispenser? Or at least scanned copies of the article posted here?
Thanks, Lee
cranetruck
94
Meadows of Dan, Virginia
Lee, if you buy "air brake antifreeze" it comes with additional ingredients. Don't think oil is one of them.
Methanol is a solvent and may negate the lubricating action you are looking for. Probably wouldn't do any harm, though, but no substitute for lubing the airpak directly IMHO.
