I needed power up my new radio AND CB AND Scanner. In another thread I learned how to get one circuit for the radio; but this left me high-and-dry for the other electronics. Warthog tipped me to a useful add-on and after researching it I was able to put an axillary Fuse Block in near the original. It makes 6 new slots available to run electronics in the ACC Key position. This as most of us know is the only way to safely run the radio without turning the truck on and struggling to hear above the din of the diesel. The whole deal utilizes a simple relay and the added fuse block $12 if you have wire and connectors already.
This is what I ended up with. The Wiring of the FUSE TAP is described above; but with the addition of the Axillary Fuse Block (AFB) - Dedicated to Add-on Accessories, the tap is wired to the Relay instead of the Radio. The radio can be added to any of SIX points on the AFB.
The relay was a standard relay from Radio Shack. The AFB came from NAPA. I combined them by notching a piece out of the base of the AFB (behind the yellow label) that was wide enough for the mount tab of the relay to slide under and used a dab of JB WELD PUTTY. This gave the unit a solid feel and now I just had to mount one stable piece under the dash.
Wire the relay with a 30" Ground- add a female connector at each end. Attach to relay. If you attach the AFB with JB Weld to the relay. Use an 8" wire with Female connectors at each end. Attach at both ends. The Add-a-tap that plugs in where the WIPER Fuse would be contains two fuses (35/10AMP)- the pigtail may need a short extension- then it gets a female connector and is attached to the relay (spade 86). Power the relay last with either a run of wire to the front battery or as I did with a short length of wire that includes a 15 AMP fuse to the 30 Spade on the relay. This SPADE end plugs into the slot right above the "R" in WIPER on the stock fuse block... and it may need to be bent upward so that the Add-a-tap can fully seat in the WIPER slot.
Parts:
- Radio Shack Relay- 12VDC/30A SPST Automotive Relay Model: 275-226 (four spades: 85,86,87&30)
- NAPA Fuse Block: Part Number: BK 7825316 Product Line: Balkamp 30 AMP.
- Add-a-fuse: BP-HHA-RP ATC FUSE TAP by Cooper Bussman (Autozone)
- Connectors/spades/Shrink tube
- Velcro/Zip ties
