Anyone else win tires on GL today?
4,647
Hopefully they're all new. If they're a "lot" of tires that have been shrink wrapped, sometimes looks can be deceiving if you've not previewed it.
M925
New River Valley, Virginia
"4 ea, Michelin, Pneumatic Tire Wheel, X 395/ 85 R 20 X2L, Max Load 12300 Lbs, DOT M50M A1JX 2009, Photos Are A Representation Of Lot."
It said they were "A" condition. They had like a gillion of them for sale.....
HOWEVER!!! HELP ME OUT.
Can you put MRAP tires on a 5 ton? They have rims....but I have the Goodyear 177s on the truck. Did I just F up again?
Does the pattern on a mrap rim match a 5 ton? Crap I did it again....
I got 8 of them.....plus the 10 pretty much new Goodyear 1100s new just old....crap.
Has anyone put MRAP wheels and rims on a 5 ton?
4,647
Nope. MRAP bolt pattern isn't the same as the 5 ton bolt pattern. It's been discussed a good bit.
3dAngus
101
Perry, Ga.
The 395s are a hot commodity for the deuce with the $110 adapter plates and about $70 worth of nuts and bolts to hold them on.
One of the best tires to mount on a bobber.
You shouldn't have any trouble getting your money back. How much did you pay for them if you don't mind the question.
4,647
There's no room to adapt a MRAP bolt pattern to a 5 ton pattern.
M925
hmmmmm.....all 150 lots or so went between 600 and 850 dollar....I got them low, hoping I could use them on the 5 ton...
Can I just get 5 ton rims?
juanprado
2,756
Metairie/La (N'awlins)
Yes, you can reuse the run flat or beadlock inside and use on 5 ton combat 2 piece wheels, fmtv, or hemett rims. The 395's will work on a 5 ton with no problem.
