nationsblake2010
- 0
- 0
- norfolk v
Ok so just like the title says I have a 6.2 in my m10009 I just cut the exh
e mufflers out to have a little less under the truck until I put my 6.5 turbo in this weekend well the truck sounded awesome until today I got in the throttle to merge on the inteeatt and the truck stuttered or missed however you want to term it. I went and changed the air and fuel filter and throughout the day it seems to be getting slightly worse. At low throttle it isn't noticeable it a that normal easing around throttle and it will stutter three or four times at what I would guess is about 16 to 1800 rpm. If I stand in the throttle it seems to clear up within a second or to. Almost like and injector isn't fueling enough. I checked all my injectors noon seem to be leaking checked oil for any signs of water or coolant in the oil nothing there the engine sound fine other than barely hearing what seems like a soft 're idle possibly. Any ideas?
