- 3,217
- 390
- 83
- Tonopah, AZ
I noticed that I have a rear axle leaking. I took the hub apart and I had gear oil in with the bearing grease and leaking on to the inter wheel.
I looked at all the seals and they looked ok. The little cork key-way looked ok also.
Is RTV the way to go and not use the cork seal or the outer hub paper gasket?
Is there anything more I need to be looking for?
Have seals on order.
Thanks!
Thanks!
