Block heater install help needed
btrapr
Monroe, NC
I have a block heater from another vehicle...I am looking at putting in my 1008...
When you place the element into the block on the driver's side does the element itself need to be pointed up/down so that the element fits into the gap between the cylinder walls?
I read that if the element touches the cylinder wall it could cause it to fail...SO if its straight up or down the is more room in between the cylinder walls....
Just want an opinion
thanks
greenjeepster
10
Southbury, CT
Usually they are installed downward, but as long as it is not touching it does not matter. You just need to make sure that it will seal properly at what ever angle you put it at.
Divemaster920
Banned
494
VA
1981-00 V8 - 6.2, 6.5L DIESEL (600W heater) 3100057 3600006 1-5/8" LC 6 or 12 o'clock N/A 1500W
This is from Zerostart.
LC=left side center
Sorry, I reread the post...I gave facts. I agree with jwaller.
jwaller
19
Columbia, SC
careful doing that you may find that it will never stop leaking. it's best to buy a new one. either way don't let the element touch metal. it needs to be free standing in coolant.
