Brake warning light on all the time
ICAT
Idaho
I put my gauge panel together but now the brake warning light stays on with the brake on or off. I know it not the switch on the "parking brake". The wiring diagram on the top of the page does not show that circuit. Do I have to look in the A3 manual to find it? :grin:
ICAT
Idaho
It doesn't have a wiring diagram but it did tell me the stoplight switch and brake warning light switch is common warning light
SCSG-G4
PSVB 3003
5,399
3,491
Lexington, South Carolina
Handbrake light is controlled by a switch that is physically turned by the hand brake handle. Up is on, down is off. Sometimes the switch needs to be located a little higher off the floor, and sometimes it needs to be rotated a bit to engage sooner.
gimpyrobb
dumpsterlandingfromorbit!
27,791
784
Cincy Ohio
They call it an idiot light for a reason. If yours stays on, you must be one.
BWAAAAAAAAhahahahahaha!
J/K is the parking brake switch adjusted right?
ICAT
Idaho
Engagement is not an issue, the light is on all the time even with the hand brake switch disconnected. I know I have an unintentional ground, I just need to find it and I figured a diagram with that system would. I sure that light is controlled by more than the hand brake switch.
gimpyrobb
27,791
784
Cincy Ohio
What else could it be? Is there a low fluid sensor in the master cyl? If not, its got to be that or the light socket, right? I'll wait for someone with more experience to speak up.
ICAT
Idaho
That give me a place to start. Thanks. Is there a wiring diagram out there with this curcuit on it?
