Charging Deuce Batteries
doghead
4 Star General /Moderator
1,187
NY
Isn't that double dipping?
Are you refering to a Ménage à trois? That will recharge anybody !:wink:
DanMartin
Hillsboro, Oregon (USA)
Chargetek 500-1
They are like $100 and perfect for a deuce. Charges and conditions both batteries individually. Hard-wire it, plug in your truck when not in use, and forget it. Just need to keep the fluid levels in the batteries up (check every month or so).
I got mine here
jdmcgowen
Klamath Falls, Oregon
Question while on this subject....
Can you use 3 12V Batts, and wire one in series and one in parrallel to = 24 volts? Seems like it would work, and work the batteries less.
DanMartin
You would need 4 batteries to do what you are trying to do...series/parallel. Basically how the 5 tons work IIRC (use 4 12v batteries in two series-banks, then each bank in parallel for make 24v with a high power availability.)
