Hi all,
I'm looking to get new wiper arms for my 1971 m35a2. I am using the stock air actuated wiper motors and was wondering if there was a wiper arm upgrade so I can run different blades instead of the dinky stock blades.
I checked past posts and one came up saying anco 41-01 wiper arms would fit. But how do they attach to the wiper motor seeing as the stock arms have a nut holding it to the motor. and the anco's look to be press on.
Any info would be appreciated.
Thanks...
18operator
It's been a year or so since I did the last one with this "kit" but I remember the arm coming with a new nut that you'll use.Ok, so I don't need the little nuts that hold the wiper arm to the wiper motor shaft?
Make sure you have the black clips on correctly. I had one on backward and didn't realize it until I had lost two wipers.It's been a year or so since I did the last one with this "kit" but I remember the arm coming with a new nut that you'll use.
I love this upgrade but it has one downside: Sometimes when you turn on the air, the motor sticks, then you keep putting more air to it and then the motor unsticks and starts swinging so hard that it will sling the blade off the arm because the plastic clip is insufficient to hold on to it. I think I am going to run a tiny machine screw through it so this won't happen. Otherwise it's an awesome upgrade.
