Come and Go Radiator Leak
Txcoop
11
Fairview/TX
I have a newly refurbished bobbed M923A2 which the radiator was flushed and renewed with coolant. No leaks were detected until last week when small drips from the bottom center of the radiator appeared. About a half cup dripped on the concrete over several days, usually in the early morning. A cold front moved through here (50 degrees, cold for Texas) and it stopped. I drove it yesterday for about 30 minutes and no drip to date. Having said of this, does anyone have a clue what might be going on? I have made arrangements for a new radiator, but do want to mindlessly replace the existing one.
Oh, by the way this is my first post. This site is invaluable when owning a MV.
Thanks,
Randy
M35A2-AZ
436
Tonopah, AZ
I would say you may have a hose clamp that may need tightened up.
Also welcome to the site.
Coffey1
500
Gray Court SC
Been there check all bolts are tight.
If they are new gasket time easy to make out of cork material.
74M35A2
340
Livonia, MI
Hi Randy, welcome. The radiator cap is a conventional type, so you can easily pressurize the system to find the leak. Don't go higher than the pressure rated on the cap though, say 10psi to be safe.
The radiator has "tanks" on each side of it, and they are secured to the main core with what seems like hundreds of nuts and bolts. Feel the bottom of each tank, and see if that is where your leak is from. It could be running down a channel and dripping at another location than what it appears. Like said above, these end tanks can be re-gasketed.
I paid $550 for a brand new radiator, and that was a pretty good deal, so try to find the leak and fix it before just buying another one.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Mine drips sometimes when it is just her time of the month. Shes moody. It comes and goes.
lindsey97
wynnewood, oklahoma
Shutterstat could be failing, and pressurizing the entire cooling system with air, causing a leak at the weakest point. I had a shutterstat fail, it caused the truck to puke coolant out of the overflow tank like it had a failed head gasket. Also had bubbles of coolant coming out at multiple hose clamps. Tightening didn't help. Replaced shutterstat and all is good.
Buffalobwana
179
Frisco Texas
On the plane on my way up to Idaho to get my 923a2 and bring it home, I sat next to a nice guy from Fairview. "I live in Frisco, where's Fairview."
He answered, "That's why I like it. Nobody knows where we are."
Home of Michael Crabtree that played for Texas Tech.
Anyway. Welcome. My radiator does the same. Leaked all the fluid out last week. It was the cork gasket on the side. I tightened up some ridiculously loose bolts and it barely seeps now. I will remove the side of the radiator and make an RTV gasket for it.
Cape Coastie
CWO4 ENG/MSS, USCG, RET.
528
125
Sandwich, MA
Also had mine leak on the drivers side bottom like Coffey1. Tightened up all the side tank bolts and she is dry now. Hope she stays that way.
Buffalobwana
179
Frisco Texas
Randy, tried to send you a PM, but it didn't seem to work. Shoot me a PM, you seem to be pretty close to me. Just down the road since I'm in NW Frisco, plus I'd like to see a pic of your rig. Sounds pretty neat.
Tinstar
2,601
East of Edmond, Oklahoma
I just tightened up my tank bolts today.
Leak gone.
Was doing a slight drip on drivers side when engine first started.
Went away once coolant was hot enough to expand the metal.
All dry now.
