gabriel mercuri
- 2
- 3
- ohio
good afternoon i have one of these generators I want to convert mine also do you have a detailed part list
contact Larry @Cowhuntergood afternoon i have one of these generators I want to convert mine also do you have a detailed part list
@Scoobyshep we havent installed a backup battery yet.
The MeBay documentation does not specify a particular Battery or a even a voltage.
What is also important is that the Plus terminal off this back up battery is grounded to chassis and the negative terminal connects to E3 on Mebay Controller!
There is a Parameter # 28 in Group 1 listed for Auto start operation, in case of mains failure for the D72 Version
I have absolutely no clue of what ABF is or what they are talking about in this parameter description
If you find any more information Scoobyshep please let us know.
@2PbfeetWow.
A positively grounded battery on a modern piece of electronics seems unusual to the point where I would be wondering about a documentation error. It would certainly have me being extremely careful. If you probe the (-) point when the controller is powered up is there a voltage?
I realize it is a long shot, but have you reached out to MeBay directly? They do, at least reportedly occasionally, respond, sometimes with useful information.
All the best,
2Pbfeet
That does look convincing similar for negative input/positive ground, though I wonder a bit at the diagram in both places of a multi-cell battery for a 1.5V input.@Scoobyshep and @2Pbfeet
when Larry and I started this project a few months ago, I thoroughly investigated this reversed battery polarity issue by checking several older D7x manuals and the controller itself without contacting MeBay.
The reversed polarity for this backup battery is consistent in all of their manuals, written and in wiring diagram.
All of their specs as to I/O’s checked out during test and implementation.
I would say that it is save to assume that this battery connection is reversed polarity for whatever illogical reason they did it this way.
We do not know what the voltage input is rated for.That does look convincing similar for negative input/positive ground, though I wonder a bit at the diagram in both places of a multi-cell battery for a 1.5V input.
Learn something new every day!
Thanks.
All the best,
2Pbfeet
@2Pbfeet@peapvp That seems like a nice find! Congratulations.
0-100V seems like quite the range though, but it does take so little to keep an RTC going.
All the best,
2Pbfeet
