CUCV ground help
NMerenda
Rochester, NY
I was poking through some stuff the other day and noticed that a ground has been disconnected or looks to be ripped off. Any idea where it is supposed to hook up to? It is grounded to the frame on passenger side.2013-08-17 15.55.52.jpg2013-08-17 15.55.30.jpg
dependable
187
Tisbury, Massachusetts
Originally, the ground wire from right side of negative buss bar was bolted onto motor with the second to rear air intake manifold bolt. Originality aside, there should be ground wires connecting chassis to motor, motor to buss bar and body to frame. Looks like you have at least one other loose wire as well, the red one over heater hose..
NMerenda
Rochester, NY
I know about the loose wire. It goes to the alternator. Ordered some boots for it already. Ill check the ground connection. Where could I go about purchasing some more ground wire?
