Deuce cab lights
bones1
Southern Maryland
Deuces did not have an option for cab (roof clearance lights) true?. I have seen some with roof lights and they looked pretty good in my opinion.
1,123
Civilian addition.
bones1
Southern Maryland
Thanks Clinto and since your here what do I use to connect an air tool/hose to my deuce under dash and at the rear gladhands. Enough pressure to run a 3/4 impact etc?. Thanks.
11Echo
91
CT W. R.
Here are a couple style of adapters I've used to connect to glad hands. You can get parts at truck stops to piece together the style of your choice.
Stretch44875
Super Jr. Moderator
Tiro, Ohio
Think memphis sells an aftermarket hardtop that has spots for mounting clearance lights.
Csm Davis
376
Hattiesburg, Mississippi
There were some 2& 1/2 and 5 ton trucks that had them I think it was a light package for europe because all I have seen had the lollipops and clearance lights on the corners.
11Echo
91
CT W. R.
The Canadian Deuce is common to have roof and side markers. You can see them clearly in this video. Listening to the Detroit Diesel and Allison automatic is cool also.
[media]http://www.youtube.com/watch?v=bNB1onHrXRo&NR=1[/media]
Wildchild467
56
Milford / Michigan
I always thought about mounting some light to the windshield frame like some TJ wranglers have. maybe that will be my summer project.:p What winch is on the front of that Canadian truck in the video? aye?
11Echo
91
CT W. R.
Their winches are hydraulic.
Wildchild467
56
Milford / Michigan
oh! because of the allison. duh.... just like the A3's Hydro would be nicer than PTO.... wouldnt have to worry about shear pins... just stall the motor or pressure relief valves. its all good.
