baxter
- 4
- 0
- salt lake, UT
I would agree to turning up the fuel but dont forget the pyro,Id hate for the next post to read how much for a new motor.
Vaughn
Vaughn
I don' think you understand what you are saying.If you run your tires at max psi and your not loaded down all you'll do is wear out the center of the tread faster and make the ride more harsh. On round tread NDT's thats not gonna matter much but if you have a tire with a squared off tread area you need to run the psi so the tread sits flat on the ground. That will get you the best tire wear and ride.
As far as the OP's question about downshifting on uphills the rest of the advice is good.
Just to be clear, are we talking about the same thing? I take your first post as you run your tires at the max rated pressure as marked on the side of you tires? is that correct?I don' think you understand what you are saying.
Turning up tire pressure to max rated is not going to do anything you mentioned. If you READ THE M35A2 TMs you MUST INCREASE TIRE PRESSURE TO HANDLE THE 10,000 load RATING APPROVED FOR HARD SURFACE ROADS!!! *GASP* You will run much more than 50PSI!!! *GASP*
The change in ride is BETTER and SMOOTHER. Your tire will not pop when you hit a pothole, nor will the rim burst.
Tire Tech Information - North American Load and Pressure Markings
"It is important to note that the maximum load is rated at an industry specified tire inflation pressure that is often lower then the tire's absolute maximum tire pressure. The tire pressures used to determine the maximum load the tire is rated to carry is based on the sizing system industry standards applied to the tire."
Like the 3000 mile oil change MYTH (started by *GASP* JIFFI LUBE!!!!) this myth of not running at max is full of just plain uninformed people spouting off sales jibberish.
The 3,000 Mile Oil Change Myth and Scam | Money Blue Book
"The 3,000 Mile Myth
The long handed down concept of the 3000 miles oil change was the brain child of Jiffy Lube and propagated by oil industry officials."
If you have proof of a tire blowing becuase it hit a pothole at max pressure, or that GL-5/MT-1 ruins gearboxes, or any of the other common myths, please post. Hint, you don't.
FYI, trailer tires can run over 100psi. Fully loaded. So your 'blow outs' and 'destroyed rims' theory falls flat... they hit the same holes, at a much higher pressure and don't detonate. And you also don't want to know what tractor trailer tires run at... 90+PSI is not uncommon.
