deuce sheetmetal
BFR
Rocket Surgeon
2,330
42
North Georgia
Anyone want to comment as to whether or not the following parts from a gasser will fit on a multifuel?
--battery box door
--tool box under driver's door
--step under both doors
--hood
--fenders (I know the passenger side will need some sawzall work for the exhaust)
thanks,
Joel
1,827
Yes to everything except the fender. If you swap both fenders you should be OK except for under hood space. Its quite a squeeze. Compare the height of the grills. When I did the wrecker I swapped to multifuel front fenders. With the gasser grill I couldn't close the side panels at all. After a few days of pondering I measured grills and the gasser grill is shorter. Changed to a multifuel grill and all was well.
BFR
Rocket Surgeon
2,330
42
North Georgia
measured and the gasser grill is indeed shorter, which is too bad as my gasser grill is in way better shape than the multi
houdel
11
Chase, MI
Ken - It seems (pun intended) that BFR is referring to the seam where the front and rear sections of the fender are joined, right about on line with the front of the door.
BFR - Since the rear fender section overlaps the front, the front metal is on a downward slope underneath the rear part. My seams aren't as bad as yours, so my thought was to to wirebrush down to bare metal and soak the seam with rust converting primer, hoping the primer would wick in between thw two pieces of metal and convert any hidden rust. Think that would work?
Also, why change the sheet metal to gasser parts? Wouldn't you also have to change the hood?
