Difference between A1, A2 and A3?
M35A2
Oxfordshire, England
What is the difference between the A1, A2 and A3 series M35's? Is it to do with newer upgrades, or has it to do with what type of model it is?
Any help would be greatly appreciated
Cheers
Andy :wink:
BFR
Rocket Surgeon
2,331
North Georgia
although there are other differences the power plant is the main difference(I think).
m44 gasser
m44a1 lds427multifuel
m44a2 ld465multifuel
m44a3 cat diesel
FSBruva
Marietta, GA
The A2's at first were all N/A multis, but subsequently they all had turbos added. THe A3's were frankensteins made from the parts of 3 A2's.... put double beadlock wheels on, repowered it with a cat diesel, gave it an automatic tranny, a hydraulic front winch and added CTIS... Am i forgetting anything?
Matt
red devils dude
Ft Campbell
not quite matt a LOT of later trucks had the N/A engine like mine a 1972 and yes it's the original engine.
it seems a lot of the 71-72 AM's had the N/A motors why I have no idea.
gringeltaube
Staff Member
2,293
Montevideo/Uruguay
Matt
Tires!!! A3s come with 14.5R20 tubeless MPT super singles. They really make all the difference! Take any A1 or A2, leave everything else stock and just put those wheel/tires on. You won't believe what our old trucks are capable to do in (should say over) deep sand, mud, snow! Air them down to 20 psi (15 rear if empty) and start having fun! On road at 50 psi you have improved handling and safety, reduced rolling resistance and much longer wear! I know, they aren't cheap, but for me it is well invested money.
Gerhard
Jones
Sacramento, California
Don't forget the up-slope hood (higher in the front than in the back) with side panels cut to match, and the aircleaner assembly outside on the right side front fender.
gringeltaube
Staff Member
2,293
Montevideo/Uruguay
Is it just because they couldn’t accommodate a radiator large enough for that Cat engine or are there other reasons for that strange looking stretched and lifted nose? Wish I could take a look under the A3s hood. Anyone got pics?
1,814
Gerhard, although I don't have any pigs of the little ugly duckling, I do have the manuals. When I start uploading manuals to the site, you want me to put those up here? Originally I wasn't becuase I figured no one had an -A3 but for the curious minds, I can upload them.
FSBruva
Marietta, GA
RDD- You're right about the N/A multis, but it also seems a large portion of those N/A were converted to tubros later. I only mention the difference because just saying its an A2 doesn't uniquely describe the powerplant.
Also, I forgot that the A3 has a roll bar attached to the frame that should lend some structural stability in the event of a roll-over.
Matt
gringeltaube
Staff Member
2,293
Montevideo/Uruguay
M35 A3 manuals
Answer: yes, yes yes! :D
There sure is a lot to be looked at! I.e. how they get the air into the front tires (CTIS).
You know that if something can't be purchased it has to be built. That's what I did with my wheels and other stuff. ... and some human beings had to convert A2(s) into the first A3!
And humans make mistakes, i. e. creating such an uggly snout :shock: , and a bigger mistake not fixing it! :shock: :shock: :shock:
But as I said, I don't know the reasons.
Gerhard
M35A3 picture attached
3116 Cat, Allison 4-speed transmission, electronically controlled CTIS
More photos here:
http://community.webshots.com/album/30269727THfhDJcfRD
Shows all angles including engine compartment and closeup of wheels.
I know the tire/wheel issue has been beat to death but are these beadlock wheels actually available anywhere?
M35A2
So let me see if I have got this right.
An M35A1 and 2 series truck can exist side by side right up until the A3 came into being? The main difference between the A1 and the A2 is the powerplant?
So if an M35A1 had the gas engine removed and replaced with a diesel, this would then make it an A2, or would it still be an A1 but with a diesel fitted?
There is a guy selling an A1 in the UK with a turbo diesel. Is this then still an A1 or is it an A2?
This is so confusing!!! :cookoo:
FSBruva
Marietta, GA
Hahahaha... almost there...
M35 = gasser
M35a1 = lds-427 multifuel (turbo, but kind of rare)
M35a2 = ld-465 multifuel (some are turbos, some are not - turbo has j-pipe, N/A has muffler)
M35a3 = cat diesel
In answer to your question, he has the LDS 427 turbo multifuel engine.
Matt
Boatcarpenter
17
Marlborough, NH
Differences
Here is a pic of my Data Plate from the truck as built. A winch has been added and soon a dropside bed. Will it then be an M35a2c W/W or will it still be an M35a2 that has had a winch and dropside bed added? Guess that may be all in the eye of the beholder.
1,814
Thats wild! Someone screwed up on that one. As we all know the NSN for the M35A2 is 2320-00-077-1616
