I discovered that the fuel pump on my M35A2 was not running. There was 24v on the plug which connects over the pump. However, the pin inside the receptacle had no continuity with the fuse inside. There was evidence of electrical issues inside the housing, and the in-line fuse had been replaced with a small metal bar. I found that if I connected the wire from the pump directly to the plug, the pump worked. After letting it run for a minute, the truck started right up, much more easily than usual. However, after shutting down, I found that the pump was not running. Does the pump have a pressure sensor, so it only runs when needed?
Thank you.
Thank you.
