Door repair, window stops
ldmack3
1,740
N. Central Idaho
I'm just about finished rebuilding my RH door but when I took it apart it had no window stops. I've looked and apparently they are part of the window and unavailable alone. I believe they are small pieces of angle with 2 slots for adjustment. Does anyone have pic or a pn/source for them?
20,541
The attached PDF on Page 330 has a diagram of the window regulator and associated parts. Page 331 has a list of part numbers. I think I see the "stop" on that picture - but I could be mistaken. Best part is that the PDF can be enlarged so maybe you can make your own "stop".
EDIT: Discovered that the window stop wasn't pictured in the Deuce TM. Found item #3 in the 5-Ton TM that shows a really crummy picture of the stop. Also has the part number and NSN listed.
20,541
Thanks but I'm not seeing it. Maybe I missed it but not in the list of parts..unless I missed that also.
Sorry. I thought it was there. I will poke around and see what else I can find... In the mean time, a video exists on YouTube that has a pretty good picture of what you are looking for. No part number - but it looks like something you could make.
Search YouTube for:
M35/ M54/ M809/ M939, all M- series door assembly tips
20,541
That is perfect!. Thanks very much. I had a whole different vision of what they looked like.
Great! Glad you got what you needed :) I found mention of a window stop in my 5-Ton "-24P" Tech Manual. Part number is below.
Page 362-1 in TM 9-2320-272-24P-2
PFOZZ (SMR Code)
5340006259617 (NSN) <<<<<<<<<
19207 (CAGEC)
7529306 (Part Number)
BRACKET, ANGLE ......... 2 (Description ..... Qty)
