engine trans bolts
3dubs
In the TM's it does not give bolt sizes. My truck is not with me and I need to replace the bold that hold the engine and transmission together. Does anyone know what size bolts are used? I also need to replace an engine mount bolt if someone knows that.
Warthog
From the TM 9-2320-289-34P Technical Manual, Figure 71, Item #7, the part number is
MS90728-63
NSN 5305-00-688-2111
qty - six required
Looking that part number up on www.tpub.com
it shows the bolt to be
UNC 3/8" x 1"
What part of the engine mount do you need? The ones to the block?, frame?, or the long one?
Sportsmanfromkc
**** Warthog, you got this site down to a T..... I am lucky to remember my login half the time and i save it to the computer everytime i do log in....guess it just comes with experiance. the more i work on my m1009 the more i can help others to.
thanks for being a constant on here and helping so many new or lesser experianced guys with our big boy toys..
yep, they are 3/8. I can attest to that being that I just did a tranny swap on mine. **** half breed ,metric/american 80's. I would use grade 5 or better.
Warthog
The long bolt is GM 460308. Looks like the dealer is the best bet.
gmpartsdirect shows them for $3.61 for a package of two.
You will also want the self locking nut, GM 6262212
