Fast idle
jag7720
Kansas City, MO
Sorry for all the posts but I am new to the CUCV and I just got my first one.
Last night it was in the 30s and I fired the truck up. It had sat for about one day. It took a while to actually fire and when it did the fast idle was really high.
Is there a way to adjust this down?
AJMBLAZER
Paducah, KY
Mine does this sorta. Does really high mean a fast idle of 1000rpm or so or fast enough to move the truck around in gear?
Mine is just a fast idle that's just the engine warming itself up. Depending on how cold the ambient temp is and the engine is it will idle like that for anywhere from a few minutes to 10+ (only in below freezing temps though). When the engine is warm it starts right up and idles at the normal low, lopey idle.
jag7720
Kansas City, MO
Yeah, I put it in gear and I MUST hold the brake.... well above 1000rpm.... maybe like 1700-2000
It only happened once... usually it is a slower "fast idle" but this one was WAY HIGH.
jag7720
Kansas City, MO
that is what it felt like ... my diesel van felt the same way ... then I changed the rubber lines under the intake manifold.
Air in the lines will cause a fast idle?
jag7720
Kansas City, MO
Weird.. so it will make a fast idle for over one minute? Never heard of that... air for me always caused a surge at start and then die.
jag7720
Kansas City, MO
I don't think it is air in the lines...
I pushed the pedal slightly down once and I started it this morning and the high idle kicked in (really high).
I then turned the truck off and started again without touching the pedal.... the high idle did not kick in...
I then slightly pressed the pedal... high idle.
So if I don't press the pedal down I don't get the high idle.
I'm guessing that this is not air in the line... And I found the adjustment in
3-71 - 3-72 or pages 205-206 in the pdf tm9-2320-289-20.pdf
