first 5 ton
bbf
port st lucie fl
i am picking up my first 5 ton in the next few weeks and my question is the 250 cummins how many miles can this motor go before a rebuild is needed . this one has 48000 miles on it
poppop
39
Brooklet, Ga
I can only give you an opinion which is on diesels in general. Most over the road trucks get several hundred thousand miles before needing to be overhauled. I expect at least 6000 hours out of my farm tractors and that would be 300000 miles at 50 miles per hour. If they are maintained and not overly abused they will last a long time. My M813 had about the same milage as yours and in my opinion it is just broken in good.
rizzo
9
Port Huron, MI
Re: RE: first 5 ton
I agree
most over the road trucks that I deal with get 750k -1000k out of the motor.
unless there is a problem with the motor, rebuild is not necessary.
BEASTMASTER
145
Burgaw, N.C.
RE: Re: RE: first 5 ton
most big diesels will get 300,000 miles no problem. the most important thing you can do is not lug the engine. especially, a cummins, they wil come apart. hence the nickname ( cumapart). if you change the oil and filters religously, that motor will be running fine if and when you decide to sell it . :driver:
joec
Vincentown,NJ
It's not even broke in yet!!!
