MogPoggers
- 95
- 18
- Jamestown, New York
Yes, I'm planning (or was planning) to put diversion valves in the tool circuit. Are there meaningful options for upgrading the front hydraulic pump, or can the flow otherwise be increased? Maybe I should be looking at just using the rear hydraulics since they're more capable, but I had seen some people mention that they didn't want to tap into those for unspecified reasons. I asked what the reasons were, but didn't get a reply. Maybe it's just that the lines for the front circuit are easier to access.You won't be able to run anything meaningful off the front hydraulics.
I ran a snowblower off of the rear hydraulics for a few years, but if I did it again I'd put valves in the circuits instead of having to switch the quick disconnects for the backhoe twice a year.
Once I actually have the thing here, I suspect the correct solution will present itself.
![DSCN5224[1].JPG DSCN5224[1].JPG](https://www.steelsoldiers.com/data/attachments/672/672185-d495615253e1f4fc94555c18fdc435f7.jpg)
