jimm1009
- 68
- 48
- Louisville, KY
The hubs have two slots cut in them 180 degrees from each other.
You need to wipe all the grease out of the outboard area of the outer race in order to see them.
It will take an 8 to 10 inch punch to knock them out. A good size it 5/16 diameter.
Knock on one side twice and then the other side twice and then back to the first side and so forth and so forth. You will have to drive it almost 7/16 of an inch before it breakes loose and falls out.
You can use the old race to start the new one in it's place but don't drive the old one too far or it will get stuck in there too.
Note: I would set the drum up on two 2 x 4 blocks of wood to aid in drivng out the outboard outer race.
jimm1009
jimm1009
