Front Diff
welpro222
Bellingham, WA
Courtesy of http://www.billavista.com/tech/Articles/Dana_60_Front_Axle_Bible/
Assembly Specifications:
ItemSpecUnit
Pinion bearing preload (new)20-30inch pounds
Pinion bearing preload (used)8-10inch pounds
Pinion bearing HP60 used in rear12-20inch pounds
Backlash6-10thousandths of an inch
front wheel bearing freeplay1-10thousandths of an inch
Ring gear bolt torque110foot lbs
Bearing cap bolt torque80foot lbs
Cover bolt torque30-40foot lbs
Pinion nut torque240-300foot lbs
Cover fill plug40foot lbs
Yoke U-joint bolts8-15foot lbs
wheel brg adjusting nut50foot lbs - then back off approx. 90°
wheel brg locknut50-70foot lbs
Kingpin 500-600foot lbs
Upper and lower kingpin cover bolts70-90foot lbs
Spindle nuts (the ones that hold the spindle to the knuckle.) 65foot lbs
Randyw
Bridge City Tx.
Im sorry yes it is a Dana 60. Pulled the pinion gear to change inner seals on the axle. Just needed to know what the specs are on the four pinion bolts.
Chaski
56
Burney/CA
That would be 80 foot pounds according to the handy dandy chart above. That sounds right, I just regeared my Dana 60 a couple months ago.
scottladdy
10
CT
According to the -34, the final spec is 85 ft. lbs. Check page 6-53 for the start of the differential installation procedure.
