So my wipers wouldn't go back down into park, were working at only one speed and there was no fluid coming out of the nozzles....replaced the entire wiper motor/pump assembly and everything worked great. During the replacement I checked the hoses, pickup in the water bottle and nozzles for obstructions/damage. All checked out OK. Haven't driven the truck in a month or so since I did this and now I no longer have any fluid coming out of the washer nozzles. Pulled the lines to the nozzles off the pump and ran it and you can hear the pump clicking over, but you only get a dribble out of one the nipples. Pickup in tank and hose from tank to pump are fine - checked those again. Fluid in tank in 3/4 full. Pulled the electrical connectors off and gave them a blast with contact cleaner. Still no luck. Any thoughts or did I just get a bad pump from NAPA?
Also, after spending an hour searching to no success last night does anyone have the instructions as to how to do the glow plug resistor bypass?
Thanks!
Thanks!
