fuel getting in crankcase
stellaruthie
New Richmond Wi
Hello all,just bought a m52a2 multifuel 465 tractor,from gsa,it was used as a grass fire rig.When I picked it up they said it ran but leaked lots of fuel in the crankcase.So I pulled the head off the ip pump to replace the 2 seals in there and they look real good.also looks like the fdc has been bypassed already.Im wondering if there is something else that could be letting this fuel in the oil,thanks alot for your help.Jeff:?:
doghead
4 Star General /Moderator
1,191
NY
Boost pump, on the side of the IP.(could leak into the oil)
doghead
1,191
NY
I guess, I would pull it off and pressurise it and see if it leaks. I think the output side should provide 60psi of fuel pressure(iirc).
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Is this the truck you wanted the ip head for? Not a whole lot to those pumps, basicly just 2 gears that mesh to boost pressure. If you think it would help, I can take some pics of an IP that has the booster pump removed. lmk
stellaruthie
New Richmond Wi
no the head is for my 109,this is a m52a2 that I havent tried starting yet,because shes getting fuel in the crankcase,thought it would have bad looking o rings under the ip head but they look good?Guess I will just put new ones in and see how it works ,thanks for the help,and maybee if you can Chris send me that pic,thanks Jeff:-D
3,150
Does it still have a flame heater in the intake? That can do it too.
