Govplanet m1038 engine question
Stevepsc
Conway, SC
I bought a 1986 m1038 from govplanet. Item number 550874. I have not cleared EUC yet, but it should be any day now. It states in the description that it has a 6.5l engine. I think they put it in wrong, as I don't think that 6.5s were available at that time. I know it is possible that it had an engine swap. Anyone else seen or heard of an early model like this on with a 6.5?
vinhvinny
atlanta GA
You are dang lucky. It is indeed a 6.5. For its bolt here is on the right
But why? Ur truck was probably upgraded during one of the maintenance visits (paint/half shaft, comm or something else maybe)
It happens.
Hopefully that engine has not been ran much. But odo appears to be correct
Congrats! You might be cleared anytime in sept.
Stevepsc
Conway, SC
Next question then......did they upgrade the tranny? I have read that the shifter lever is different, but have not looked at a lot of pics to see.
vinhvinny
atlanta GA
I did look. But i could not find a pix of shifter. If you ll see P for parking then it is an upgraded trans 4L8...... St im not too sure. Somebody might chime in on that.
Chief_919
100
Western NC
I doubt they changed the transmission. When 6.'s went out of producton 6.5's were used as replacements when an engine was bad, and since it is a direct bolt-in swap it was no big deal. Changing the transmission is a much, much more involved process and wasn't done unless the truck went in for a total rebuild where everything was swapped.
