Grounding MEP-002 in Garage and Type of Wire
mrcarman
Salt Lake City, UT
If this has been addressed somewhere else, I apologize. But I looked at the Wiki and the grounding threads and couldn't find an answer--or at least an answer that I recognize as a solution.
I have an MEP-002 in a utility trailer (non-military--just regular utility trailer). The unit is new to me and the grounding rods are missing. The engine is running fine but I have hesitated to engage the AC because it isn't grounded. Is there an easy way to ground it within the garage? I would like to engage the AC and do some load testing by plugging in a couple of electric heaters into the two outlets.
Also, what type of wire would be appropriate for running from the ground connection on the frame on the generator to wherever I ground it to?
Thanks for any help.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
If the motor is running, you should have AC. There is no on/off switch for that. There is no need to worry about a ground to test the unit. You only need to worry about that when hooking up to house service.
Isaac-1
SW, Louisiana
If you want to you can ground the frame by running a suitable wire from the ground connection point on the frame to any good ground point you have available (meter water pipe, steel I beam, etc.) This can help protect you from some types of potential electrical shocks if there are certain faults in the generator, but in reality there are many other ways it can kill you that adding a ground wire will not help, so be careful.
319
Lieutenant
49
Michigan
You could go to any home improvement store and buy an 8' ground rod, clamp, and 6 awg wire for about $20.
Harleyd315
Denville,New Jersey
I don't think you will put much of a load on the set thru the convenience outlets or is it recommended. To truly load test the unit you need to connect to the output lugs.
mrcarman
Salt Lake City, UT
Thanks, Isaac. Are you just saying generally don't do anything stupid or are there other things I should be especially careful of? My family would very much appreciate me not killing myself with this little hobby.
Isaac-1
SW, Louisiana
Mostly don't do anything stupid, which means you have all the usual dangers and you should treat it like any other engine when it comes to mechanical injury, plus any time it is running you should treat it as a live electrical circuit, in addition any time you are working around in the control box be aware with one bump of the wrong wire it could come to life almost instantly, energizing the rest of the cabinet.
Ike
p.s. also keep in mind that when dealing with generators you are often dealing with a situation like you would have with line to line connections around your home even when your thinking of them as line to neutral. (always treat all output wires as if they were hot, as all it takes to have a floating neutral is one bad connection point in the reconnection switch)
